Guest ADRIAN
What Size Is The Hub Nut?
Guest ADRIAN
I'm almost shure about it beeing 26mm...
not shure tho.. :)
Can someone tell me?
Thanks ,
Adrian.
saveloy
34mm for the 1.9 & 28 or 32mm I believe for the 1.6.
I have seen 32, 34, 35 and 36mm on 205s.
seems to vary, but I recently had to buy a 35mm socket and it was listed specifically for peugeot/citroen hubnuts in the tool catalogue!
aftermarket driveshafts get whatever size nut they have to hand when they make them.
The hub nut on my 1.6's driveshafts are all 30mm at the front & 32 for the rear drums but all the 205 1.9 & 309 ones I've worked on have been 35mm on the front & also for the rear discs iirc.
Never found any with a hubnut smaller than 30mm either way.
Graham.:)
jj205
Yes my hub nuts are 35mm on my 1.9 gti, but today when i was fitting my new drivers side driveshaft, wellreconditioned from autofive, i found the nut supplied was smaller than 35 mm, ive only got a 30mm big socket and 35mm socket, so neither were useful, ive bought both sockets specially both of my 205s, 1.1 and 1.9
I think its something like 32mm this nut i got with my 1.9 driveshaft, but i just used the old nut 35mm as it looked new any tightened up okay, i think its time i got a big socket set,
Jonathan :)
Edited by jj205
speedy indy
its 35 on my 1.9....
Hilgie
35 on my 1.9 GTi as well.
The 1.6 GTi has 32.
