dale205mills
Peugeot 205 1.6 gti road rally
dale205mills
Edited by dale205mills
dale205mills
All so fitted some of my Baker mounts bits
allanallen
This is way too nice to use!
dale205mills
Thank you for the kind words I blame zakham engineering up in wales with there mk2 escort builds but as we all no with 205's, build it right the first time and it will last
Robbiedundy
Lovely car and your garage refit looks awesome love the flooring good work B)
dale205mills
I brought a quaife quick rack a couple of weeks a go and with being on lock down again I decided to rebuild my rack
dale205mills
I have all so sorted fitting up the front sub frame and gear linkage
dale205mills
Some more today as some of you may no I am on Instagram and have got a you tube that I have started video what I am up to both my names are dale205mills please add me of both if you want to see a bit more of what I get up to cheers.
dale205mills
Update today, Ihave started putting my tear beam together and having a dry fit on car to double check on a few things and I have stripped down some rear trailing arms, rear drums. Been to my local motor factors for new cylinders, brake shoes, handbrake cables. They where unable to locate any new rear drums but digging threw my spares I have found some near new ones. There is a new video on YouTube if you are into that sort of thing
More photos
dale205mills
Front to rear brake lines run today and sort out wireing in side the car before deciding where to fit foot rest.
dale205mills
Evening
Been putting in the hours over the last couple of weeks doing work on car, underlay fitted with carpet that was trimmed to fit
dale205mills
I have also rebuilt the fuel pump with a adapter and a aftermarket pump
dale205mills
I have also finished off rear brake line with clips and fitted new heater matrix
