Connor
Water in Sill
Connor
Hey,
Are there any drain holes in the 205 sills? I'm pretty certain there is water in my drivers side sill since under breaking there is a splashing sound. It looks like the sills have been worked on at some point at the front so I'm hoping that they haven't welded any holes up, I've had a poke around and couldn't really find anything though.
Cheers for any help.
Connor
Callum
Theres a bung underneath near the rear that might have been sealed over or stonechipped, there's a cross in the middle you should be able to push your finger through it, I removed mine completely. Also there's 3 or 4 flutes aling the sill that water can weep out of again that could have been sealed over so check and use a sharp knife to cut through it if so. There's loads of info if you do a search on the forums
