Telf
Electric window help.
Telf
I'm having an issue connecting my electric windows.
As far as I can tell the wires are all connected on the driver's side as I have no loose plugs or cables anywhere. On the passenger side i have a white plug coming from the door conduit into the footwell . It is for the motor and switch ( as far as I can tell)but  I cannot work out where it goes. Initially I thought it plugged into the fuse box but I dont seem to have any spare slots.
I am pretty sure that the window motors dont work unless both sides are connected correctly although it's been nearly 3 years since I last had to do any work on the window system.
Any help,advice,guidance or pictures would be really appreciated!!
SRDT
I have this, in French and for LHD but probably close:
ob_8e1aa3_30-1-leve-vitre-electriques.jp
"PC7 ba" is a white plug and "PC5 mr" is a brown one.
  • Thanks 1
Telf
Finally sorted this. On the passenger side I had a cable incorrectly connected. Wire codes on the cables alerted me to my error. On the driver's side the multi earth cable that I now know plugs in under the dash was hidden inside the pillar. I'd not pushed it through as I assembled the door... Took ages to realise!
