Callum
Where can I buy a new tps?
Callum
I've tried a couple motorfactors and no joy does anyone know where i can buy a new one? Could someone give me the part number as well thanks
Callum
I've found a part number for it and can get one for £52 + vat from part alliance, also when I googled the number auto doc has them as well, which is the best brand to go for?
Edited by Callum
Bosch is OEM but it's just two microswitches as opposed to a potentiometer so a pattern part should be fine.
Callum
Okay thanks out of curiosity what's the difference? When I gave parts alliance the part number 1628g4 they said throttle potentiometer
Edited by Callum
Almost all cars use a potentiometer so they are just assuming that's what they are selling. If the part number matches it will be a switch.
The difference is that a potentiometer or throttle position sensor can read 0% throttle, 100% throttle or any other value in between there whereas a throttle position switch turns on for 0% throttle or 100% throttle but if it isn't at either of those positions the ECU just knows that it is somewhere in between those two points.
1628G4 is the Peugeot part number, it's a Bosch part in the Peugeot box and the Bosch part number is 0 280 120 327.
Callum
Can't find a bosch one, what are the reviews like for facet and hella?
DamirGTI
Facet is Italian brand , been using facet quite a bit but mainly for the dizzy caps and rotor arms .. cheap but decent made , myself had no issues using facet parts .
Hella is German , kinda pricey , but also better quality/durability .
Over here i can find OE Bosch switch new , but it cost really too much - around 200-220gpb .. (Bosch number is 0 280 120 310)
Known good used Bosch switch should still be good , if you don't mind used one .. i rarely saw them faulty .
D
Edited by DamirGTI
dcc
I'd just fit a working 2nd hand item, it's literally 2 micro switches
DamirGTI
Me too .. an used one would do , if it's not for an total "nut and bolt" restoration with new parts as a must .
I have at least 5 of them , OE Bosch all in good working order ..
D
SRDT
You can look for Bosch parts here:
https://www.bosch-automotive-catalog.com/fr/vehicle-search
Quote
Part number 0280120327
Designation Throttle valve sensor
Production discontinuation 11/2007
Type formula DKS
Article status
Discontinued item
Quote
Brand Name
 Article Number
CITROEN 96 081 740
CITROEN 1628 G4
CITROEN 96 015 940
PEUGEOT 96 081 740
PEUGEOT 96 015 940
PEUGEOT 1628 G4
DamirGTI
0 280 120 327 TPS seems to be OE , but i always found 0 280 120 310 TPS fitted on 205's ...
D
Callum
Thanks everyone for your replies, I was going to replace my current tps because I've changed the serviceable parts on the ignition system ready for when i have the car set up and put on a rolling road in a couple weeks so i wanted to make sure everything was in top working order but it sounds like I don't need to worry about renewing it just for that
Edited by Callum
DamirGTI
No need really .. as said they rarely go bad , and even if they do you'll hardly notice it on Jetronic system ! worst thing that can happen if the switch breaks is it'll heat up the exhaust manifold by not closing/cutting off the fuel supply on overrun ..
Can check with an multimeter if the switch is good to verify .
D
I've had loads fail but I'm used to Mi16s (same switch) which are a pain when they don't switch to idle correctly.
DamirGTI
Yes , been working on a few 405Mi16's , the idle goes mad with the bad or poorly adjusted TPS switch !
Maybe the Mi16 TB spindle as it wears , does the damage to the sensor as well ? making them more prone to failure ..
I'm "overstock" with the TPS sensors as they simply do not break on my 8v ! .. collected some here and there @ the scrappy and such , but never needed one as an replacement .
D
Edited by DamirGTI
It wouldn't surprise me if the worn throttle bodies were the cause, I've got lots of those too but they are all useless.
I got a couple of brand new ones actually but they are XU9J1 (or whatever the 8v 405 Sri/BX GTi engine is called) parts so the bore is smaller but I'm hoping I can use them to refurb a 16v one. I haven't looked at them in any detail yet though.
I keep threatening to make a jig to bore and bush the Mi16 bodies to put them back to good. Should get on with it really.
DamirGTI
How about XM/605 2.0 8v TB ? it's the same shape/type but with bigger bore :
