MrAndy
Mr Andy's 205 Family
MrAndy
It's been long time without updating anything. Bought a set of B6 dampers and will install them with Eibach springs. Meanwhile I've been cleaning and painting the front suspension parts. Hope to get that finished and the front end put together soon.
-A-
SootySport
How do you keep track of all the work  on 4 cars?  I have trouble with just one.   Keep up the good work.
  • Haha 1
MrAndy
After long time, took the gearbox end cover out to replace it with a repainted one and found a surprice. The input shaft end nut (with holds the 5th gear packet together) has become loose causing some ugly-looking marks.
uc?id=1sMDE9NSfL_L3Qka9ASHp_8Ves6k9WMeu
uc?id=1u6eQi3soeMSslLJJzD-ivRx_kLmMWaty
uc?id=17e_qT8ts1zIiZrO7uf9VvMJeJg-9tzXY
The fifth gear things looked like OK and there was no bigger particles in the oil, but the oil was very dark as you can see.
Now asking for opinions how to continue?
1. Best choise, remove and open the gearbox, wash everything clean inside and then rebuild.
       + The front suspension and driveshafts etc has already been removed.
       + This would ensure everything to be 100% OK
       - I've just finished everything on the engine bay side and everything is working there, it feels that if I now put everything into pieces again, I will never get this car running :( (I had big hopes to be able to do some testing this summer and maybe even try the MOT and now this happened)
2. Put the cover back on and put the suspension back together. Fill/rinse/flush the gearbox couple of times with diesel&oil mix and rotate it in the air engine running idle. Then putting new oil in and be happy
       + Much easier solution than 1.
       - Will it be clean enough after this??
       - Will the cleaning liquid come trough the seals and spoil the clutch plate and clutch fork  pressure-bearing??
What would you do??
-A-
Edited by MrAndy
MrAndy
Here is a small instruction set of how to build rear brake calibers, if anyone is interested:
1. All parts cleaned and ready to rebuild..
uc?id=1mkHZjeE9h_nwemgdUp4heHQuz1FCLJmz
-A-
MrAndy
2. First thing to do is to install the hand brake seal.
uc?id=1KPyAQanCNJbY-bxsfGhtaWLnWw_RfVcJ
MrAndy
3. Hand brake Screw and spring washers
uc?id=183PMTnInD3KbjSV8oFasogiBA_-Urs3q
MrAndy
4. Nice drawing to show how the spring washers will be installed
uc?id=13ByNO-GBoAVKcozCubA3AKgXqBb0oIu1
MrAndy
5. Hand brake lever parts before installation
- I used lot of Black MOS2-Grease on all the parts not contacting directly to rubber gaskets /seals and CRC-Brake grease on parts that are in contact to rubber seals and/or brake fluid itself. Correct me if you have different opinions on that.
uc?id=1kq5m2Oi95qKom8cU6pAA9-uEAw1MG6Wk
Gohn
good pictures and info andy,
you must have a 205 magnet in your pocket, they just stick to you !
noticed the ones imported to finland have the little headlight squirters, haven't seen them before
did you end up rebuilding your gearbox ? or flush and run new oil in it ?
MrAndy
6. Hand brake lever installation #1
- I used Wise to squeeze the spring washer packet enough to get the lever into place. Be carefull with that and PROTECT YOUR EYES!!!
uc?id=1oQUreHm4NIfMhd6bxrKOduOD10fKfef_
MrAndy
Hi Gohn, thanks!!! The headlinght squirters are a Nordic option. (FIN / SWE / NOR) at least in Finland they were mandantory at that time.
The red car with gear-box-thing is waiting my decision to go full route or not (to paint the whole car properly or not). I got tired of not running any of those for too long time and decided to get the Grey GTI into MOT and driving condition for next summer. So the brakes are the GREY-GTI-brakes.
-A-
MrAndy
7. Hand brake lever #2
- Here you can see the Auxiliary spring alignment. Don't forget to put it in :)
- GREASE ALL places
uc?id=1u85BiK9ro1zqyBveP5A_GGBoQEzucAl-
MrAndy
8. After sliding the lever into place, put the Locking ring into the groove also
uc?id=1pbcvHwkrODWy6rLnTH6CB8GwRFDmJQFf
MrAndy
9. The aux spring before and after snapped into place
- I used a sharp screw-driver for installation
uc?id=1koH80hQGWnABfCq_0GD9IG3pAA1jPSAi
uc?id=1iT5SA66Nu_GnGBVoUfyvNrdnFPakY1K7
MrAndy
10. Protect the whole assembly with MOS2-Grease
- This part is messy, thought this for a long time, but I have put 2 of these into pieces and both were done like this originally (from 2 different cars..) so decided then to do the same thing.
uc?id=1WIl_jjg0woajGq-1ia_ruuScRauA2YpE
MrAndy
11. The main rubber cap on.
- Challenge, try to do this without messing your hands =)
uc?id=1mN_Uq6yDG_LsemOPlWQ9VhZCqBMieo9_
MrAndy
12. Brake piston parts before installation
uc?id=1A89uVb-xbFATVA9hJy7fmY7yyBlf2EC2
MrAndy
13. The spring and pressure/thrust bearing waiting to be put into piston.
- The spring end must go into the small hole inside the piston bottom
- I lubricated this with fresh brake fluid
uc?id=17DQsGeVbsiOReEhesZRgcuAKMG3tbrM7
MrAndy
14. Piston installed and ready to be put into cylinder
- Slide the seal first into the groove (WITH GREASE)
- The piston goes nicely in (WITH GREASE) by pressing and rotating same time clockwise
uc?id=1psUUOy-cKDFHo-pSmPsy7KVP5MXTHG4T
MrAndy
15. Piston installed and dust seal waiting for installation
-  I used the CRC-Brakelube with these parts
uc?id=17E-CaVfjiHn0_gJVtRfxvuWppGAscJ6g
MrAndy
16. The dust seal installed
- You can see nicely the fabrication date stamped here :)
uc?id=19M7qNwqCNddQynKYyvWT2BqMOP6tIave
MrAndy
17. The sliders waiting for installation
- The is nothing special putting them in
QUESTION??? - The pin ends are different (thick vs narrow), which direction is correct for installation?
uc?id=1yd1Aouyihm1J-nxjIsJg48RAa-iLNHMQ
MrAndy
18. Complete :)
- QUESTION - In these pictures you can see the direction I selected to install the sliding pins. Is this correct way??
uc?id=1PegzDZh7_L-t_MvOdRSqXaetw4_IDyLt
uc?id=1988LRiXrjvooteUUbS-bT0al0w_64qyi
uc?id=1GDJyy-CwaPoY7poFtkgoIJZZUuteLBsx
MrAndy
19. The atmosphere of the work site
uc?id=18E6uQF9xEQsZGgv5i4NbNJxESB8eyOhp
cybernck
What a superb guide!
  • Thanks 1
