dale205mills 39 7 Cars Posted January 3, 2019 9 hours ago, jackherer said: No! It's what they call a 'flying lead loom'. not the 4 cylinder fully assembled one for three times the price! This: Not this: Thanks jack Share this post Link to post Share on other sites
Miles 331 1 Cars Posted January 4, 2019 Most phase 1 dash's are the same, its only really the A and B reg ones that are different along with the entire loom again. Share this post Link to post Share on other sites
ArthurH 8 Posted February 18, 2019 As part of the work we have done over the winter, we have run new wires to the transponder. It is very simple wiring and I'm sure it will be OK, but I do like to check things before race days. Does anyone know a way of testing that a transponder is working correctly away from a circuit? Share this post Link to post Share on other sites
ArthurH 8 Posted July 9, 2019 Another question. I discovered that both the high and low pressure fuel pumps are being powered through the loom by the same, comparatively thin, blue wire. It looks like a previous owner has used a chock block to splice in a 'spur' connection to the HP pump. I'm not sure what current the pumps pull, but the one wire looks inadequate to me. I would have thought that GTI models would have left the factory with a HP pump, so there should have been a second wire in the loom. Is that the case? If so, any idea what colour it would be? Share this post Link to post Share on other sites
