I need to have my car set up properly as i feel its not performing how it should be.
Since owning the car i have fitted a cambelt kit, plugs, leads, dizzy cap, rotor arm, all fluids have been changed, cleaned and oiled the air filter, replaced the coil, new fuel and genuine oil filter and also changed the engine mounts I also only use v power fuel.
The engine starts and runs okay but i would like the throttle body cleaned as the revs can be between 1000rpm and 1500rpm, I've checked for split pipes but couldn't see anything i will be fitting a new tps for peace of mind, ill also have the afm cleaned then everything set up to basic settngs and optimised on a rolling road.
I spent sometime looking through thread after thread trying to find a guide with all the figures but I couldn't find one just bits of information here and there. Would someone be able to tell me the figures for setting each part up so I can give them to the tuner so they know where to start thanks
