PhilNW
Replacement OIl Cooler pipes
PhilNW
How long do oil cooler pipes last for?
Best place to get replacements as NFP?
boldy205
I'm not familiar with the standard set up,  but if they are removable,  as in not 'fixed' to the cooler etc then I'd say a local hose specialist.
As for how long do they last? Just check for perishing really .
I cut the ends off the old pipes and silver solder on -10 fittings. Then use push lock tube. Works out about $100 all up.
Like this.
