Gaz205
Ignition Amp Paste
Gaz205
In the near future I'm renewing the paste behind the Amp. Already bought some, quick question do you let it dry? Or reattach it wet so it applies to the backing plate too?
A search doesn't find that answers and apologies if it's a silly question, I've never renewed it before .
Apply it and attach it straight away, it only dries out after many years and then it needs replacing.
Gaz205
Thankyou , may help with a mid range hesitation it's picked up.
Ozymandis
Apply a thin even layer using a spatula/scraper/filler knife, then attach it whilst wet.
 The old style paste Peugeot used stays wet throughout its life, supossedly.
Many pastes on the market now, set like silicon sealer, I dont like those and I see more failures in semiconductor packages with the set type pastes than the older wet ones. Its the commonest failure point in high wattage LED COB packages. In replacements we always use wet paste it defo lasts better.
Gaz205
Well mine was totally non existent, not even only crumbly stuff. Applied a thin layer of new with a small spatula and unfortunately there's no noticeable difference. Cleaned up the earth while I was there too. Still have my 2/3k hesitation.
Annoying to say the least...
Telf
the paste that you apply when fitting a CPU to a motherboard works well for this job
Gaz205
It was a computer retailing place I bought it from, came in a syringe with a spatula. The research I did seemed to suggest it was ok.
AFM swap next. My spare made it worse oddly.
paul mcgrath
Gaz205, Let me know how you get on. Mine drives like dog at low revs (under 2500) low throttle to the point where if i have to maintain the same speed, i dump the clutch till i need throttle. Otherwise the engine jumps about on the mountings like no tomorrow.
I tried the paste (mine was non existant as well) made no difference, so maybe a duff amplifier - or something else!!! Didn't put a thin layer on mine, whacked it on as nicked a massive tube of it from work!!! Presumed that tightening it up would set the thickness.
Telf
The point of thermal paste is to provide a medium to increase the thermal conductivity between your CPU and the base of the heatsink. If you put too much, it actually acts as an insulator, which is the exact opposite of what you want. In the worse case scenario, you can overheat and damage components.
This is a direct quote from a PC build thread- it seems too much paste has the opposite effect to what is required.
Gaz205
Mine was lovely all through the rev range, I can't attribute it to anything at all.
I put a thin layer on. Ill be stripping and cleaning, repairing everything I can on the ignition system and dizzy.
Then it'll be fuel pressure test etc. No money will be spent until I've done the basics this time.
Ill update you though.
Edited by Gaz205
Typo
Gaz205
Fixed this now.... New paste, re routed the coil and distributor wire so there was no risk of contact and changed the fuel filter.
Pulls cleanly now.
Gaz205
*** Broken again***
think I've disrupted a loose wore somewhere, suspect the dizzy wire, it's threaded a bit. It's a screw in type. Does removing the screw also remove the wire/plug? Allowing an attempt at repair?
