Andy Willis
205Gti6 Master Cylinder
Andy Willis
Does anyone know roughly how much the master cylinder needs spacing/angling by to allow it to clear the gti6 rocker/cam cover?
thanks
Andy
j_turnell
Varies from car to car some need hardly any at all others need a fair bit. Same with exhaust clearance. Best off dropping it in and taking it from there.
Andy Willis
Ok thanks
dobboy
Do you not want to shave the cam cover?
iirc there is quite a bit of meat on the cover where it needs to come off.
Andy Willis
If I can angle it up to clear the cam cover I would rather do that
Richie-Van-GTi
loads of options, angle the engine, lower the engine, re-angle the servo, shave the cam cover etc.
Best bet is get the engine swinging on top and gearbox mounts then see what clears where and make a decision.
Edited by Richie-Van-GTi
Andy Willis
Thanks, i'm aware of the tilting engine idea however i'm not personally a fan, i'd rather keep the engine in its intended position. I plan on re-angling the servo.
As James said each car is different which never helps, some fit with very minor adjustment, others are a right pain in the ....
Fit the engine in without the M/S fitted, fit it and see what needs adjusting
