Daxed
Refitting Scuttle Panel - How?
Daxed
The first 20 mins of my planned full weekend on the car in prep for the Retro show next weekend has got off to cracking start... It's painfully obvious I could continue trying to fit the plastic scuttle panel until it gets dark and still be no further ahead.
Is there a knack to getting the plastic back under the bottom windscreen seal? Start at one particular end? Start in the middle? Use a cable as in fitting a screen? Pray to any particular deity?
Any advice gratefully received as a refit without further damage would be rather nice.
Telf
I just lift the corner of the seal and wiggle it in. The panel needs to not be screwed down. A bit of soapy water also helps.
Use a non metallic implement to assist it under the seal- its easier if the windscreen wiper arms aren't fitted.
That's how I do it at least
  • Thanks 1
Daxed
Cheers Telf, wiper arms off, panel loose, trim tools in hand. Hoping soapy water is the missing ingredient.
Daxed
Lubricant made all the difference. Straight on in 2 mins.
Thanks again.
Telf
its all about the lube!:D
Daxed
And the 2 mins sums me up well.
