Moby 0 Posted May 22, 2018 Hi everyone, my 1.6 GTi sunroof leaks and im looking for a replacement but seems the tilt sunroof is not so common to find. Can someone suggest an alternative sunroof that fits exactly to the same cut out without too much hassle. Thanks in advance Share this post Link to post Share on other sites
SootySport 23 Posted June 6, 2018 (edited) Can you not fix the existing roof? What part is leaking? Have you tried reaming out the drain tubes or changing any rubber seals? I wouldn't think an aftermarket roof would be of the same dimensions. Edited June 6, 2018 by SootySport Share this post Link to post Share on other sites
farmer 328 1 Cars Posted June 6, 2018 The britaxsunroof are not in bed to sort Be just a seal Share this post Link to post Share on other sites
Moby 0 Posted June 6, 2018 It’s not Britax it’s panaramic. I think it’s the seal that leaks and the hinge is also broken. I’ve asked Dave Fowler too he hasn’t got one. Share this post Link to post Share on other sites
toolie72 67 1 Cars Posted June 8, 2018 Mine used to leak, chased it for yonks-eventually found it was water creeping under the frame not the seal Share this post Link to post Share on other sites
