Braymond
Tachometric relay
Braymond
On mine, this relay sits loose in the little cubby hole to the right of the steering column. Is this normal??
I'd imagine it should be secured to something rather than just flopping about in the the tray? But I cant see anywhere obvious that it otherwise be secured to...
It's meant to be secured up by the ECU to the M6 stud closest the driver AFAIK, but I suspect that the mounting clip/bracket thing on the top of the relay has broken off so it's been left loose.
