B1ack_Mi16
Dipstick for the Mi16?
B1ack_Mi16
Does anyone know where to get a new dipstick for the XU9J4?
They seem to be NFP and mine is broken.
farmer
I have 2 or 3 tucked away (alloy block)
A cheap solution is to cut an 8 valve one down
B1ack_Mi16
That would be an idea. So 1.9 8v dipstick then as a start?
farmer
Yes, would keep costs down
As the alloy block dipsticks command good money
Bakes100
As above, I've just used a remarked 8v dipstick.
B1ack_Mi16
Thanks guys. Ordered a 8v one. Does it need to be cut down much so that the oil level will be in the "twisted" area of the stick?
If so maybe better to cut it close to the top an weld it there?
I haven't done one for years but IIRC the oil level doesn't end up on the twisted part. You just need to cut the excess off and then cut the two notches in it.
farmer
Service box says the XU9J4 alloy block stick is
ENGINE OIL GAUGE
LONG 491
