sp_en_ny 17 1 Cars Posted January 16, 2018 Hi Everyone, I have a 92 CTI, can anyone tell me or point me to where I might find out what instrument lights should work when turning the ignition on but also when driving. I am pretty sure I have most of the standard ones working but would be nice to know what if any don't. For example when low on petrol the warning light does not illuminate, nor does it when turning the ignition on. I think the STOP light should illuminate when you turn the ignition but that no longer lights up. Many thanks Share this post Link to post Share on other sites
Telf 224 2 Cars Posted January 16, 2018 It will be the bulbs that have gone- they are pence to replace buy a hand full remove the instrument cover and dials and replace as required Share this post Link to post Share on other sites
jackherer 543 Posted January 16, 2018 The stop light should turn on with ignition because the low oil pressure light triggers it and you don't have any oil pressure when the engine is not yet running. So if your low oil pressure light works and your stop light doesn't it's probably the bulb as Paul says. But if the low oil light also doesn't work it might be a wiring or sensor problem. The low petrol light doesn't illuminate with ignition, it only turns on when you actually have low petrol. You can test it by unplugging the sensor (under the rear seat) and shorting the terminals together. Share this post Link to post Share on other sites
sp_en_ny 17 1 Cars Posted January 17, 2018 thanks peeps, any idea what type of bulbs they are and where to get them ? Share this post Link to post Share on other sites
jackherer 543 Posted January 17, 2018 They're called 286 capless bulbs and you can get them from pretty much anywhere that sells car parts for pennies. Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted January 17, 2018 Ebay is often best for stuff like this. Car spares shop will sell you a packet of 2 for £1.99 or something. Ebay 10 bulbs for a quid etc. Share this post Link to post Share on other sites
sp_en_ny 17 1 Cars Posted January 19, 2018 Thanks fellas. Much appreciated. Share this post Link to post Share on other sites
welshpug 1,666 Posted January 19, 2018 there are different wattage bulbs, though I've never noted what goes where but I would imagine the STOP light etc would have the 1.2 and the rest 0.9 or thereabouts. Share this post Link to post Share on other sites
