floodys
1.9 rear wheel bearings, complete hubs or bearing?
floodys
Need both rear wheel bearings for the 1.9 205, it’s a 309 beam so I don’t suppose I makes any difference?
 The bearing/hub that came out was a SKF446595. Just want to know if one can get just the bearing to press in or doni need to buy the whole hub and bearing assembly?
its a complete assembly, just look for 205/309 disc rear bearing and you'll find rhem
floodys
Cheers, quick look on GSF, ABS lists @ £75 and non ABS @ £143, quick comparison and they are the same sort from the width shock must be the ABS ring? Worth getting the ABS one even though not having it? To save £££
What is up with what you have? It is possible to tap the inner race out, clean out the old hard grease and re grease them. As you can see they aren't cheap!I
floodys
Having stubs done by Allan and pulled old ones off thinking just new bearings, didn’t realise it was complete units, they will discount down so not to bad. Old ones are all over the place plus not sure if I have all the ball bearings!
Even ABS equipped 205's didn't have ABS specific rear hubs (ABS is on the front axle only) so I'd guess they're actually listing ZX/306/Xsara rear ABS hubs.  If that's true, AFAIK they're wider (hence the different offset disks) and won't correctly fit a 205 length stub axle.
floodys
Only going on the GSF website or lists 2 for 205 1.9 non and with ABS, as can be seen in pics all sizes are same apart from what I think is the “abs ring?”
careful with GSF, if its a Vetech branded item I would avoid them.
also as mentioned the 205 never had abs sensors on the rear so you don't need the abs ring, and it may not fit.
the bearing itself may be identical and the difference in total width and longer stub axle may be due to the spacer behind the bearing, so there's a chance it could fit with the ring removed, however some rings are not removable.
floodys
Anyone got a recommendation of where to get these then at a reasonable price?
never bought any personally I'm afraid but the last one I fitted came from a local factors in the silver premier box and was an SNR item, SNR provided most of the OEM bearings that peugeot used back then.
Also had reasonable success with Firstline bearings, many of them have been SNR stamped.
In the past the GSF bearings have all been 306 ones so don;t fit, also the clearance on the stub axle pin meant you could slide them on and off by hand (No good) Look at mister Auto, bearings are not cheap mind for good ones
allanallen
I can supply a quality bearing (normally FAG) for about £70 each if its any help Ian.
