B1ack_Mi16
Other injectors for standard Mi16 engine?
could have had some stock injectors serviced and fitted and driving by now...
B1ack_Mi16
Indeed, however there is months till the rest of the car will be ready anyway :D
nixonmi16
Hi I run 0280155746 ev6 4 hole injectors of a Volvo 960 216cc flow rate for the past 3years these are a direct fit and a lot quieter that the old fat body injections
B1ack_Mi16
Btw. just to sum this thread up.
I can confirm that the 0280158013 EV14 Bosch injectors that was availiable for 17£ each + vat indeed was genuine items.
I installed them with some injector extender hats on the top and got lazer cut some suitable aluminium rings to space them up and make sure they are a tight fit between the fuel rail and the manifold (due to the missing possibility of using mounting clips).
Engine seem to be running just fine with them at least.
ZNOkCzQ.jpg?1
unariciflocos
Thanks for this, had the same idea, will order the same just now.
