Powers
Omex 200 Base Map Required
Powers
Hi guys,
After a base map for a Xu10j4rs bottom end using a Xu9 8 valve head with twin 45 Webbers. Obviously it will be mapped but just after some thing close.
woodymi16
Hi guys,
Have you tried Omex tech support, I got my start up map from them.
Powers
All I got was the answerphone. I will email them to see if they can help
Fill the table with 10 deg BTDC. That should make it run. Once youve established it runs and all the sensor appear to be reading correctly get it to the mappers. I dont recommend driving it like that but it probably will drive. Some OE manufacturers use 10 deg as the limp home mode in case of comms failure to the ECU e.g. Ford EDIS.
johniban
i got a 600 map ive tweaked myself
