colti
Diesel And Gti Coolant Header Tank Differences?
colti
As the title.
My 2.0 turbo has always been fitted with what l guess is a Citroen XM part(Black,angular) and it leaks at the cap seal point.(I've tested the cap which is a fresh uprated motorsport cap.)
This guy is selling diesel tanks that look like they have the same pipe stubs.Could it be the level sensor connection is blanked?
http://www.ebay.co.uk/itm/NEW-BIRTH-FRONT-COOLANT-EXPANSION-TANK-RESERVOIR-HEADER-OE-QUALITY-8527/263088917798?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l9372
That's an early (Ph1 and 1.5) GTi header tank that was also fitted to later non-turbo diesels.
Yours sounds more like the later (Ph2) GTi header tank that from memory was also used on TD models. That's black in colour, sort of rectangular in shape with the level sensor on the bottom.
You can physically interchange them, but the level sensor is wired differently.
colti
That sounds right.
So to use the white eBay tank I'm going to need a blank or a level sensor to match the tank. As it's a track car I don't need a working sensor. Tempting to fit an ally motorsports tank...
a level sensor is just as important if not more so on a track car.
True, although it's all relative - most of them don't work anyway these days in my experience.
