wladimir031
Gti6 Stroker 2044Cc
wladimir031
-Xu10j4rs Head (GTi6) fully rebuild , port and polish
-Xu10j4rs block with S16 (xu10j4) rods and piston
- td crankshaft 88mm
my questions is :
- which bearings I need to use (GTi6 oem?) ?
- my static compresion will be arround 11.5 ? or above 12 ?
- td crankshaft ,whether there are any modifications to be placed in gti6 bottom ?
​ sorry for my bad englishh .. cheers
XU10 mains bearings
XU9 or XU10 rod bearings
XU9 thrust bearings, check for 0.07-0.27mm end float, various thicknesses are available
approx 11.2-11.5:1
TD crank drops straight in.
wladimir031
XU10 mains bearings
approx 11.2-11.5:1
tnx peter .. one more question for you ... How much will be a valve clearance at TDC .. i have i plan in future to put newman ph2 264* cam, do I need to pocket s16 piston ? 1.1mm headgasket thick
No idea, you'll need to measure it but better than a GTi6 piston. That cam is too small for that spec anyway. The dynamic CR will be too high.
wladimir031
Does this mean that that spec will not work normally on the stock gti6 cam?.. until I buy biger cam ..100 oct fuel ?
wladimir031
DCR will be about 9.5 ... advance inlet cam for reduce dcr ?
Edited by wladimir031
wicked
No retard; it's about the closing point; where the compression starts.
Edited by wicked
ra40
With 88mm cranck and S16 pisotns+rods you will be 1mm over the deck.GTI6 gasket is 1.2 and you have to pocked the pistons with >1mm for standard GTI6 cams in order to keep safety clearence at TDC.If you plan PH2 Newman with 1.4 mm lift@TDC you need 0.3 mm deeper pocket.
I disagree.
eg
S16 piston compression height = 39.1mm
S16 rod length = 152mm
half stroke = 44mm
XU10 block height = 235.1mm
39.1 + 152 + 44 = 235.1mm
wladimir031
I confirm, piston is flat with the block ..
wladimir031
I gave up from newman ph2 (to small) ... ill buy later catcams 4903156 (281* 3.30mm@tdc, but only 10mm max lift) , or 4903109 (274*/267* 2,0/1.4mm@tdc , 10,95 max lift) , with pocketed s16 piston +2mm .. I do not know yet , every thought is welcome ...
wladimir031
i measure my valve clearance to piston at TDC .. Inlet is 4,2mm and exhaust  4,5mm (with gasket 1.1mm)  ... enough space for cam for 2.0mm inlet@lift at tdc (274*)?
You need to allow 2.3mm of clearance, minimum. The inlet valve will actually be closer after TDC and reduce this by approx. 0.25mm.
4.2 - 2.0 = 2.3mm
Thus only just.
wladimir031
I pocketed piston +1.5mm  ... (only inlet side) now i have 5.5mm clearance at TDC ...
i measure :
CR .. it will be 11.2-11.3:1 ...
with catcam '109 (2mm@tdc)  now DCR will be around 8.9/9:1
Grantpipe
How did this work out and what cams did you use. I’m planning a similar setup
wladimir031
I've packed everything now,for now they are stock cams (retarded inlet) I'm waiting catcams 4903109
WP_20180213_20_35_37_Pro.thumb.jpg.7abdd51c83d4903944b332464abe4512.jpgIMG_0318.thumb.JPG.de0e2b1f750ced8818f7b072921ad703.JPG
voldo
4.2 - 2.0 = 2.3mm
Thus only just.
Why so much clearance? Catcams recommends minimum 1.0mm valve-piston clearance and preferably 1.5mm. The Catcams 4903109 should go in this setup with OEM valve pockets if the above specs (Intake 4,2mm and exhaust 4,5mm) are correct.
Do as you wish, but most hydraulic lifters run at 0.080" min on the inlet and 0.100" on the exhaust, minimum. You might be confusing hydraulic with solid lifter clearance.
Edited by petert
Awesome, well done.
mmt
Sounds great.
Is the TD crank worth the extra efford? Will it be more powerfull/more torque over a standard GTI6 engine?
Could you have used std GTI6 rods and pistons with extra deep valve pockets machined?
Thanks.
wladimir031
Much more powefull over standard  .. i must remap ECU to get full power..
NO i used piston and rods from S16 (xu10j4) with td crank (88mm)
mmt
Cool.
PooRicH
so nice man
