artois7
Mi16 Headgasket Bits
artois7
Hi all,
Need to do the headgasket on my mi16. Been putting it off for a while now.
Can anyone provide a full list of the bits I need and where I'd be able to source them from? Need to do it on the cheap so likely only doing the gasket & skim, plus any other absolute essentials that I'm not aware of?
Thanks.
If you want cheap look for ECP specials, Quality parts don;t cost much more and if your keeping it worth doing which I can supply
Head Gasket
Stem Seals
Spark Plug O rings
Cam cover O rings
Inlet Gasket
Exhaust Gasket
Head Bolts
Cam Lube
Cam Seals x4
artois7
Do you sell as a kit? 1.9 mi16
artois7
Yes bar the spark plug seals
Found a kit on your ebay shop but doesn't seem to include the head bolts. What is the kit cost?
Head set with bolts and delivery is £125.00
