toolie72 67 1 Cars Posted September 4, 2017 Start car-usual clattering etc Take car down dual carriageway into town-get blue oil cloud that starts after two minutes and disappears?? after another two minutes No smoke at idle (hot or cold), no smoke on way back up the dual carriageway?? Head reconned about 8 months ago (I fitted stem seals myself thou) So I'm left thinking 1) sticky stem seal 2) manifold got oil in in and it sometimes sucks the top of it (no porn jokes please!) 3)sticky oil control ring I have to say this appeared after a long constant throttle run on ordinary unleaded-seems suspicious Anyone got thoughts on this? NB I am planning a bottom end rebuild but I'm struggling for a block (to do it at my old fart snail pace) Share this post Link to post Share on other sites
Tom Fenton 1,561 Posted September 4, 2017 Check all the breathers are clear, the rubber hoses go soft and collapse. Share this post Link to post Share on other sites
toolie72 67 1 Cars Posted September 8, 2017 Good call but alas no Until the car is warm she is now a two stroke!! Worse the longer it's lain so looks like some numpty ballsed up the stem seal (me) but strange as its been fine since last Christmas But oil must be weeping past into cylinder (just not enough yet to do the "idle" cloud Joy of joys Share this post Link to post Share on other sites
pugdamo 111 2 Cars Posted September 8, 2017 Normally if it's stem seals/guides you will end up with a cloud of smoke when you first start or have been on over run and go to accelerate, if it's smoking until warm that could be as Tom day said (but you ruled out) or worn rings. Share this post Link to post Share on other sites
toolie72 67 1 Cars Posted September 8, 2017 Its worse when you coast downhill-give it a blip and hey presto a cloud But as I say once it's warm it's gone Have everything for a bottom end rebuild (so do head again) apart from a block as I gave it to dundy cos he needed one Tsk always the way Cars my daily so would prefer to build a short engine to drop in it #trawlscrappies lol Share this post Link to post Share on other sites
DamirGTI 345 Posted September 8, 2017 Are the valve guides replaced during the head recon ? and is the engine "noisy" ? Steam seals , if bougt individually per piece out of proper sealed packing , tend to go bad pretty quick .. Another thing , which i learned the hard way ! , if the bottom end is more than moderate "porous" (rings/liners) and you seal up just the top ie. the head with new stem seals , guides etc. the pressure will be greater towards the bottom end and it'll start burning oil/smoking How much oil you're losing ? D Share this post Link to post Share on other sites
toolie72 67 1 Cars Posted September 8, 2017 Guides were done at head recon Engine does have a ticking sound like a valveshim but again it's not always present-certainly no ominous sounds/knocks It's not running out of oil but it is a crazy amount of blue smoke that comes out at first I think next port of call is a) find my compression tester to check all values are about the same check valve clearances then rip head off to see wtf going on AFTER trip to new York (keep wife happy) Share this post Link to post Share on other sites
DamirGTI 345 Posted September 9, 2017 Leak down test would be more accurate , if you have an air compressor can do the leak test with the compression tester hose just undo the valve from the hose end .. D Share this post Link to post Share on other sites
steve@cornwall 100 Posted September 9, 2017 What sort of shape is the oil filler /breather tower in? The spun metal baffling can choke up, oxidise and compact. I have removed this in the past, allowing vented oil and condensation into the plenum, getting pulled straight in rather than sitting trapped and having time to drain back down, I guess. (Was better with the cap undone) Share this post Link to post Share on other sites
Tom Fenton 1,561 Posted September 9, 2017 A Stainless Steel coarse pan scourer makes an ideal (& cheap) replacement for inside the filler/breather tower. Share this post Link to post Share on other sites
toolie72 67 1 Cars Posted September 10, 2017 What sort of shape is the oil filler /breather tower in? The spun metal baffling can choke up, oxidise and compact. I have removed this in the past, allowing vented oil and condensation into the plenum, getting pulled straight in rather than sitting trapped and having time to drain back down, I guess. (Was better with the cap undone)Took it all apart and cleaned them both in a bucket of petrol a couple of weeks agoYesterday am took throttle body etc off and cleaned chamber out (not much oil-just enough to get on good tshirt!!) Still the same down the dual carriageway Get into town, little puffs-park car,come back an hour later,no smoke Think a seals/valve stems picked up and is ok when warm OR the run down the dual carriageway amplifies the smoke cloud I'd get driving through the town so I can see it When I come back from hols I'll do head and see what's up On an upside it'll be snowing up here before long so you won't see the smoke officer! Share this post Link to post Share on other sites
toolie72 67 1 Cars Posted September 28, 2017 Update New German valve guides (last Christmas) are away Wtf- got spare head that’s in bits-it’s guides are better (swapped valves about in case it was valves) Oh well, finish taking spare head apart and it’ll be getting a quick skim then swapped over AT A DIFFERENT MACHINE SHOP Share this post Link to post Share on other sites
steve@cornwall 100 Posted September 30, 2017 Was thinking of this thread this week when reading another article, albeit about 2 strokes. Because 2 strokes have oil introduced directly into fuel, some finds its way into the exhaust. Once the exhaust is hot enough, it smokes heavily until burned off. Seemed to fit your symptoms. Share this post Link to post Share on other sites
toolie72 67 1 Cars Posted October 1, 2017 Haha my symptoms?! No my symptoms are unprintable!! Took spare head to different machine shop on Friday, he agreed guides were good,heads never been skimmed Strangely he never tried to sell me any “extra” work The quickest I can get it is this Friday Busy place Share this post Link to post Share on other sites
camgti 56 Posted October 11, 2017 Ive had this issue recently. Turned out to be blocked breathers forcing oil up and into the inlet. Worse on the motor way when you put your foot down. Meaning more pressure more oil. The blockage was in the oil hose down near the block. Cleaned it out including the filler neck and all the screens. They were filthy. MThe screens/mesh are held together by a very small nail the runs theough the center across ways stopping them from unwinding. Unroll them and soak them. They come up like new. The car has never run better. Do this whilt the head is off. Will make it so easy to do. PM me if you need to know how to take the whole filler apart, there a little knack to it. 1 Share this post Link to post Share on other sites
