Henry Yorke
Motoronic Distributor Oil Leak
Damoleary
@Henry Yorke did this fix sort out your problem in the end with the dizzy not adjusting , I am having the same trouble with the same dizzy
this was an oil leak problem, not an adjustment issue.
the ignition timing is controlled by the ecu on this particular variant, engine speed/position comes from the crank sensor.
Henry Yorke
Yes I did sort it but it was just an oil leak and there is no adjustment on the motronic as Welshpug said
