sp_en_ny
306 Gti6 Headgasket Set
sp_en_ny
Moring all,
Seems the HG is on the way out, looking to buy a HG set including bolts. Anyone able to recommend the best place and brand(s) to get it from ?
Spencer
I use OEM gasket, Payen bolts and seals elsewhere, I have a fairly local engine remanufacturer that can supply parts.
sp_en_ny
Thank Mei,
Can you still buy a complete kit ? Just rang my local Peugeot and gave price for the HG only. If you cant buy a complete kit can anyone advise what I would need that you would expect to be in a complete kit ?
I have a mate who has and going to help me do it so i can get my hands dirty and hopefully learn a thing or two, but I need to get the parts and as I have not done anything like this before not sure of everything that I need. All that has been suggested is a full HG kit and head bolts.
never seen a full kit for the RS engine, there wont be much in it really so build the oe gasket then everything else aftermarket saves a fair few quid.
head kits tend to be more useful for diesels that have numerous gaskets, rocker/cam cover seals egr seals and all that gubbins, or 8v xu's, though half the gaskets in the kits aren't applicable to most engines usually!
Don;t buy a Kit as you normally end up with a crap HG, As above OE MLS gasket and buy the rest separately, Stem seals, Inlet/exhaust gaskets
sp_en_ny
Ok I have hunted high and low for a mls gasket but the only ones I come across are fibrous ones. Is there anywhere online that I can order one from ?
I don't know many Dealers that sell online...
that said all the aftermarket gaskets I've seen for this engine certainly are MLS anyway, though I wouldn't choose to use any of them over an OEM as they're no cheaper and have the rivet tabs in the wrong place.
Edited by welshpug
dobboy
I bought a full Payen head kit, and then an additional repair gasket (1.4mm?) from Pug, as I had a skim.
