lahondal
Power Estimation?
lahondal
Hi all.
Im finishing a 205 turbo 8v project and im waiting to the mapper to give me a date to take the carnto him and get the machine mapped.
Its my second aftermarket ecu but my first modified engine as the previous engine was a nearly stock Gti6 engine with only ITBs and a slightly hotter inlet cam on it.
It mades 162cv at the fly after mapping (with my "street done" map, and 174cv before mapping, which is a (in my opinion) a low value, althought the engine was not refreshed and cames from a scrapyard to the car as it is.
This mades me have some doubts on the mapping.
Now i have to send this car to the same mapper and i would like to know a approx value of the power the engine should have, for reference, as i lnow there are many turbo 8v engines in the forum. I would like to know if the mapper is doing a good job or its ok to move to another mapper.
The engine specs are:
-Fully refreshed xu10j2te engine, (rings, bearings, etc)
-Custom ex manifold with 40mm ID primaries, non equal lenghts (1-4 long, 2-3 short)
-T28 turbo from a nissan 200sx.
-60mm downpipe and exhaust all straight pipe from front to rear.
-DKZ cam.
-Front mount intercooler, 2" inlet pipes.
-Megasquirt engine management.
Plan to run on 1.1/1.2bar max boost, depending on the power result (be gearbox limits this).
What do you think?
Thanks!!!
Edited by lahondal
wicked
Think 240bhp @1.2 on a realistic RR and mapped properly..
Maybe limit the torque/boost a bit around 3000rpm to get a flat torque line. Saves your clutch and you'll get a nice predictable engine to drive on the limit...
Edited by wicked
lahondal
Ok, if thats true i think we will keep it below 1.2 al least the first races.
Will be driven be a newbie rally driver.
wicked
Mine does 220bhp @1.0 with similar spec, but TT manifold and td04hl and vems ecu.
Use detcans during mapping...
lahondal
I think the mapper have a good detonation detection method.
I have an audio amplifier connectdd to a knock sensor and works fine.
colti
Hi all.
-DKZ cam.
What do you think?
Thanks!!!
Did you build a loom to go with your Mega squirt?
I've always stayed with standard ECU but the rebuilt original XM loom has never fitted particularly well...
