Stian_P
Removing Rear Lights
Stian_P
Hi everybody.
I am trying to remove the rear lights on my 205, but can`t seem to find out how. Is it the bolt behind the little panel inside the light? Am I right in that there is nothing inside the boot that needs to be done?
There's one M6 nut behind the light. You'll need to remove the screenwash bottle on offside, nearside nothing needs removing but it's behind the felt cover.
j_turnell
Long reach 8/10mm behind the light cluster inside the boot. You'll need to remove the washer bottle on one side to get access IIRC. Unplug the wiring and it will come off.
Stian_P
Thanks guys :)​
