Josh_Quant
Rear Disc Conversion Concern
Josh_Quant
so night I made a started on the rear disc conversion but have come across a slight problem where the nut sits slightly proud of the stub axle by approx 5mm if that..
So the parts I'm using are..
306 spacer behind bearing
306 stub axles
306 disc and pads
306 bearings
306 calipers
205 calipers brackets
205 bearing washer (306 are thicker)
question is this something to worry about or any had this problem?
The nut should thread on far enough that you can stake it, ie a few mm of stub axle stuck out from the nut.
Same issue both sides and were both stub axles the same length?
if the stub axles are recently fitted they may not be fully home.
Josh_Quant
i know disc are shot but just test fit
How tight have you had the nut??
Josh_Quant
F**king tight to make sure it didn't rip threads
mikeyd
think there are 2 different length 306 stub axles if you have bits from different cars
Josh_Quant
Fitted the other side today and the shaft stuck a lot more past the nut so I think your correct mikeyd
