toolie72 67 1 Cars Posted May 13, 2017 Few weeks I've had a cracking sound coming from footwell Seems to be worst at power on/off but engine mounts are ok Changed driveshaft (was on list anyway), been in about with the spanners (and crowbar!) all bushes are good, drop links, wishbones,subframe,anti roll bar etc Only bit that's I'm not sure of is lower engine fork as I can move it with crowbar I've even had carpet up to check floor lol Roundabouts are where you hear it most and it's most definitely a metallic cracking sound (hence why I checked floor #paranoia) Anybody had similar? Share this post Link to post Share on other sites
welshpug 1,646 Posted May 13, 2017 check the bottom of the top engine mounting bush, these can crack whilst still appearing tight in the cradle. 1 Share this post Link to post Share on other sites
steve@cornwall 100 Posted May 14, 2017 Did you check the steering rack to subframe bolts? Share this post Link to post Share on other sites
toolie72 67 1 Cars Posted May 14, 2017 Steering rack, clamp etc checked before Will check engine bush when I've fixed no water in house, bolox Share this post Link to post Share on other sites
toolie72 67 1 Cars Posted May 15, 2017 Mei- you get the cigar Lower thread on engine mount bush was 1/4 turn slack Loctite and a larger Peugeot bush fitting kit (bigger chisel and lump hammer)-sorted Many thanks for pointing me in right direction Share this post Link to post Share on other sites
