bobdylan_55
Pedals 205 Same As 309?
bobdylan_55
Hi all,
If somebody is able to give me some advice on the below I would really appreciate it.
I am currently looking to fit my 309 with some standard pedals (currently has a pedal box setup). I unfortunately don't have the original setup so am on the look out for throttle, brake, and clutch pedal setup including the pedals (obviously), servo and master cylinder, and any other parts that are required including fixings.
Now my question is, are the 205 items the same as the 309 items? as obviously this massively opens up my search area for parts.
cheers
Bob
Yes they're the same as 205s. The brake and clutch is anyway, I'm not 100% sure about the throttle.
Edited by jackherer
bobdylan_55
Do you know if that includes smaller engined models or just the gti? I presume the servos and maybe master cylinders are different sizes?
clutch uses 2 different cable ends, Early Phase 1 acc pedals are different as well but finding one of those would be unlucky
bobdylan_55
Cheers guys
Clutch will need modifying to suit my tilton hydraulic release bearing anyway so thay probably wont be a massive issue, it was mainly the servo and master cylinder setup i was concerned with. Anybody got any of this for sale :P
allye
I do actually have a complete pedal box spare!
bobdylan_55
When you say pedal box do you mean standard items or a pedal box as in OBP or tilton etc? I'd really like a standard set so if thats what you have I would defo be interested.
cheers
