isis 0 Posted April 11, 2017 My 1992 1.9 GTI has rear suspension that performs well but never had a rear beam rebuild after 100k miles. I do however get a sporadic sharp ' crack' noise emitted over larger bumps and wallows or hard cornering. It sounds as though some part of the beam is perhaps dry and slipping. The beam seems to perform, so I am confused. Thanks. Share this post Link to post Share on other sites
barneys66 122 1 Cars Posted April 11, 2017 Check shock mounts..? Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted April 11, 2017 Rear beam mounts, especially if it's wallowing about. Baker BM do a full kit to replace them for not alot of money. I've a set of his Group 'A' beam mounts (acetal bushes and machined alloy blocks) to go on mine imminently. Mike Share this post Link to post Share on other sites
isis 0 Posted April 11, 2017 Thanks boys. I will test those points. I actually have 4 x 1.9s and all of them have the same sporadic,sharp, loud crack noise over larger dips and bumps. What are the known symptoms for the beam needing a rebuild? I have tried jacking one car up and testing for movement from the rear wheels, but none it seems. Share this post Link to post Share on other sites
welshpug 1,656 Posted April 12, 2017 the only 100% failsafe method is to strip them down, most of the time you cannot feel the play with the dampers torsion bars and arb attached. Share this post Link to post Share on other sites
jackherer 543 Posted April 12, 2017 If the anti roll bar end plate bolt loosens it can make a lot of noise. As already said though, rebuild it before it's too late. If you wait until there is obvious play or negative camber it will be much more expensive to rebuild and may need a new crosstube. Share this post Link to post Share on other sites
steve@cornwall 100 Posted April 12, 2017 May sound daft, but spare tyre deflating with time and allowing movement in the cradle? Get a nice tyre on metal sound too Share this post Link to post Share on other sites
isis 0 Posted April 12, 2017 Thanks guys, I will report. Share this post Link to post Share on other sites
