Gaz205
Bolt Sizes
Gaz205
Hi I can't find anything on here that really helps. I've done a hell of a lot of bolt cutting and now need to replace.
Can anyone help with the lengths and diameters please for:
1.Valance to bumper nut bolt and washer sizes
2.Suitable nut and bolt size for the bumper bars (not the under wing ones) to weld a captive bolt in place of the original welded in bolt
3.The length of the T bar bolts on the rear outer and front outer sides of the bumpers.
4. Denji drivers light nut to secure to the driving lamp bracket
Thanks in advance
Leslie green
1 id say m6 maybe 20 to 25mm they are quite small from bumper to valence
3 there are 30mm and 50mm t bolts I suspect the longer ones are used on the sides as they have a slider to go through on the front bumper(mine are missing too) ,not sure on the rear side but there is a rubber bush there too with the shorter bolts front and back.
Edited by Leslie green
farmer
Sign up to servicebox
All sizes etc are shown
Gaz205
thanks for the suggested sizes, I'll see how I get on before signing up- I have no idea whether I'll be able to get an account on there
Edited by Gaz205
farmer
It's a useful tool for part numbers information and learning
Anybody on here would recommend using it along side forums
