Gaz205 50 Posted March 21, 2017 I have searched and can't find the answer... What size drill piece and subsequent size door pins (hammer in version) tends to be the best tried and tested ? Thanks Share this post Link to post Share on other sites
Anthony 1,002 Posted March 21, 2017 Standard ones are 7mm on earlier cars. I drilled mine out to 8mm as the holes were worn and used generic 8mm roll pins. Door is perfect now with no sagging/droop Share this post Link to post Share on other sites
Gaz205 50 Posted March 21, 2017 (edited) Thankyou, just what I needed. Normal quality metal drill bit? And where did you source them from? Thanks again Edited March 21, 2017 by Gaz205 Share this post Link to post Share on other sites
speno 239 2 Cars Posted March 21, 2017 I've got some new pins some where . Best of with an angle air drill Share this post Link to post Share on other sites
Gaz205 50 Posted March 21, 2017 I've got some new pins some where . Best of with an angle air drill Cheers, I'll drop you a text Share this post Link to post Share on other sites
Gaz205 50 Posted April 8, 2017 Still need to find these hinge pins... Struggling on the eBay front to find roll pins at 8mm other than for a vw transporter, can anyone suggest a seller? Thanks Share this post Link to post Share on other sites
speno 239 2 Cars Posted April 8, 2017 Just type in 8mm roll pins . Share this post Link to post Share on other sites
welshpug 1,646 Posted April 8, 2017 what's wrong with the vw ones? if they fit get them! Share this post Link to post Share on other sites
Gaz205 50 Posted April 8, 2017 what's wrong with the vw ones? if they fit get them!They are £12 each!! Share this post Link to post Share on other sites
toolie72 67 1 Cars Posted April 8, 2017 I used m6 cap head bolts with nylock nuts I used thin washers "chapped" in to take up vertical play I can tighten them up to remove play (once a year before mot lol) Share this post Link to post Share on other sites
Gaz205 50 Posted April 8, 2017 I used m6 cap head bolts with nylock nuts I used thin washers "chapped" in to take up vertical play I can tighten them up to remove play (once a year before mot lol) Good idea! I've seen the spring pins, the guy doing my car said they should work failing that he likes your idea Share this post Link to post Share on other sites
farmer 328 1 Cars Posted April 8, 2017 Just get a normal pin and sheath it with a coke can or something Share this post Link to post Share on other sites
Leslie green 104 Posted April 8, 2017 (edited) The problem drilling them to 8mm is access there won't be room for a normal drill that's why you need a small right angle one as mentioned above ,you can get m8 roll pins on ebay up to 70mm long eg ebay number 232244307444 5 for 2 quid Edited April 8, 2017 by Leslie green Share this post Link to post Share on other sites
Gaz205 50 Posted April 8, 2017 The problem drilling them to 8mm is access there won't be room for a normal drill that's why you need a small right angle one as mentioned above ,you can get m8 roll pins on ebay up to 70mm long eg ebay number 232244307444 5 for 2 quid They are the ones I have seen, thanks. He says he has the equipment to drill it so we are giving this a go. Share this post Link to post Share on other sites
hoodygoodwood 70 3 Cars Posted April 8, 2017 Before drilling the holes out I would order the new pins and wait for them to arrive , check the diameter of them with a micrometer and drill the holes a little smaller so they are a good tight fit . Share this post Link to post Share on other sites
Gaz205 50 Posted April 8, 2017 Thanks for the tip, with the play in these they lay go straight in! Share this post Link to post Share on other sites
toolie72 67 1 Cars Posted April 9, 2017 Hmmm could a tapped hole with a grub screw taking up the play do the same thing-it would at least take some slack up and be easier to drill, through the side My mot man said anything would do as long as doors didn't drop when he checked them I just used cap head bolts as they're better bolts Share this post Link to post Share on other sites
welshpug 1,646 Posted April 11, 2017 you need a new MOT tester I think never seen anyone check door hinges on a test. grub screws wont work as the pin needs to turn in the worn section. Share this post Link to post Share on other sites
