fila1223
2.0 Mi16 Running Rough
fila1223
Hi
For past half of the year i was trying to diagnose my engine but with no luck.
Basically car struggles to maintain idle and revs with great effort to, and exhoust smells of unburned fuel.
I'm getting spark everywhere and lamba was replaced recently, but i discovered that engine is running smoother on 3 cylinders when i remove first coil from gearbox side.
Does anyone have any idea what is going on ? I'm seriously running out of ideas.
is the map sensor pipe intact?
done a compression test?
fila1223
compression 12,5 bars on each cylinder
map sensor is sealed
i wasn't able to find any vaccum leaks either
Edited by fila1223
hoodygoodwood
Its got to be worth fitting a new spark plug and coil to the cylinder closest to the gearbox , if it runs the same or better when that coil is disconnected the problem could be there .
Tesstuff
Check your purge valve.
fila1223
Both new and it runns better when i disconnect a coil
And i don't have a purge valve, the donor car didn't had one
Edited by fila1223
Tesstuff
If the purge valve is missing, how is that circuit blocked off? I presume the carbon canister set up was removed at the same time, but how was it plugged?
fila1223
If that would be the case wouldn't it runn fine on cold engine ?
Motor runns the same when it's cold and warm
fila1223
anyone have some more ideas?
calvinhorse
Ignition amplifiers, try swapping them around or replace them
Passenger side inner wing area
fila1223
All ready tried that
I have spark on each cylinder and it still runns like crap.
Maby all of my amplifiers are bad?
Edited by fila1223
calvinhorse
Absolutely possible yes
How old is the fuel and fuel filter?
Mine always ran like crap on anything other than super unleaded
fila1223
Fuel is about 4 days old and filter is brand new
calvinhorse
I'm gonna 100% go with ignition amps if you're saying all 4 coils work?
Only other option is ecu which is unlikely but the map sensor is in the ecu but that wouldn't cause a misfire
fila1223
You know what, ecu might be the problem
I make vaccum with hand pump on map sensor and it runns better. It's not a problem with vaccum tube itself becouse i can see that vaccum isn't escaping on gauge. I tested other tubes for leaks but i couldn't find any
fila1223
So i guess it is't an ecu falt since i changed it and engine is running the same as before
Mikey S
Map sensor pipe collapsed internally?
fila1223
It's new
What might be a symptoms of bad cam position sensor ?
