soundguy
Spade Size - Earth Blocks
soundguy
I'm making up a couple of mini 'earth looms' because I binned the earth junctions near the headlights. Does anyone know what width the spade was inside the original earth junctions? These are to tap into a new section of loom which was provided to me, which would have plugged into the binned earth junctions (if that makes sense).
So basically, the new yellow blocks on the new headlight section of the loom are to plug in to the standard earth junctions, which are gone - so what spade size should I use on the end of my new earth mini looms to plug into the supplied yellow blocks?
farmer
I have some new earth plugs if you want to retain them?
