Jogon
Peugeot 205 1.6 Auto - 91
Jogon
I have a fair few 205's sitting on my drive just now (no GTI's just now) one of them is a 1.6 Auto which turns over but won't start, checked the fuel, fuel pump, plugs/distributor etc and all appear to be functioning.
Last stop is the crank sensor, I've purchased a replacement but I can't actually find the sensor, anyone have a clue as to where it may be? I've tried the obvious places.
Edited by Jogon
Daviewonder
It won't have one.
steve@cornwall
Is 91 carb or single point injection?.
carb if it has a dizzy, injection models had a coilpack from my small experience of them
steve@cornwall
Good point, Mei,. Suspect auto choke then if it's not been binned yet. Off with the air filter, open the choke butterfly by hand and either pour a few mm of fuel directly into car or spray in some easy start.. cross fingers and attempt a start
Jogon
It was indeed the choke butterfly and thanks for the pointer, much appreciated.
It's sticking a little, started straight off, but as soon as i closed the butterfly it stopped, or when applying the foot to the pedal, gave it
a few mins and it started ticking over on it's own with air-filter back on and it's at least starting now (and over running when switched off) but
this particular vehicle has been on Sorn for 8 years (although started up and driven around a yard every few weeks)
It's been so long since I've tinkered with a petrol 205 I've forgotten about carbs and how to sort the autochoke mind.
