willysjam
Section Behind Rear Wheel Arch
willysjam
Has any got a photos or can tell me what grommet holes are in the small section behind the drivers side rear wheel arch please. I have cut out what was left of a rusty section and have made the new piece but I think there is a solid grommet and possibly one a pipe goes through! You can see the top of the hole for the section by removing the rear wash bottle (if this helps.
Also can anyone please tell me which HP (engine number) my engine will be in a 1991 1.6.Need to know to buy parts!
Thank you
Minty Sauce
Your engine will be xu5ja 115bhp
murtaghp
One of the groments is for the sunroof drain to go through and the other I believe is just a blanking grommet.
When I repiared mine, I just drilled a 20mm hole for the sunroof drain to pass through and didn't bother with the other one just to fit a drain.
One of the guys on this forum was manufacturing these brackets a while back and there are some excellent photos and drawings on his post.
Have a look at this link: http://forum.205gtidrivers.com/index.php?showtopic=144204&page=1
willysjam
Thank you both. I will have to find the sunroof drain pipe!
steve@cornwall
A new member from Cornwall ! Welcome, Jamie
pugdamo
Never even noticed that because I'm on the mobile version, welcome jamie.Nice to see another down our neck of the woods.
mrfirepro
photo showing sunroof drain hole and tube if it helps
willysjam
Thanks for the welcome Steve and Damian. May see you around when I get the car out and about. Thanks also Paul for the drain hole pic.
Not sure if you can help but I am having trouble with my paint code! There is a lot of info on here and elsewhere but the guy I ordered an aerosol from said the code I have provided isn't right?
It is laser green, but he says the code isn't green as it says on a forum link!
The codes have worn away on the car.
Maybe I should have posted this somewhere else on the forum?
Any ideas please?
pugdamo
The code for laser green is m0ss
willysjam
Thank you Damian, I will try that.
Mikey S
It was skyQuake (Mike Farrow) on here who did the reproduction rear bumper brackets that you need. Maybe worth a pm to him to see if he still has any. I bought a pair for mine and they were dead reasonable.
Mike
