kachel
It's Running! But Not Well.....
kachel
I got my 1.9 dfz engine running after it didn't move for 3 years. I did some repairs and now it runs direct after starting. But it goes directly to 3000 rpm and after 4 seconds it dies when I do not hit the throttle. When I help the engine by keeping it above 1500 rpm it stays running. Under the 2000 rpm it does not run well.
Where to start looking for the solution?
I know two things aren't correct at the moment, the ignition is from a 1.6 and the vacuum hose from the ignition house to the inlet manifold is missing.
toolie72
Classic signs of an air leak-races then dies
If you keep it running with throttle does the car move like it going off/on?
Blanking off the missing hose with duct tape would be a quick check (and cheap too lol)
j_turnell
As above sounds like a bad air leak to me. .
Telf
check the bolt on the inlet manifold that attaches the oil filler neck is secure.
If its loose It lets unmetered air in causing an immediate rise in rpm to 3/4000 revs. car usually dies shortly after due to excess air
kachel
Problem solved, it's running well! It was exactly like you described, the bolt from the oil filter neck was not secure and the hose from the brake system to the inlet manifold was missing.
Out of curiosity, what does the brake system do with the vacuum from this hose?
assists your foot in pushing the brake pedal down.
kachel
Ah, so it's not an essential issue
lagonda
Not perhaps for running the engine, but you'd be alarmed at how long it will take to stop the car without the servo working!
Telf
Glad to help Rob. Its only knowledge passed on from other forum members when I had exactly the same problem!
