N3VRAM
Malpassi Filter King
N3VRAM
Hi All,
Does anyone have any experience with these? I'm looking at the glass bowl one with 6/8mm tails. Looking at the item I'm curious about how it works as I notice fuel is drawn from the top rather than have the pressure regulator underneath. To me it would seem this could cause fuel starvation issues, hence why I'd like to know how it works!
Also I assume a fuel gauge is a requirement for these as you can't tell what PSI you are running without one?
Thanks,
Matt
mikeyd
alloy bowl version is better - used to run one on an escort rally car on carbs and would supply enough fuel [tarmac or gravel events ]to pull 8 k rpm no problem
the pressure guage you are thinking of is for setup only --- not for normal use!!!--- best get it set up properly on a rolling road and you should have no trouble
