jdman
can some one identify this bearing size below are the numbers on it
806 880
4150
10-89
what size it was in 1989 is quite irrelevant tbh, all I can tell from that offhand is that its not an oversized bearing
you need to check the crankshaft, fit some standard bearings and check the clearances, only then will you know what you need.
jdman
main bearing s/c 17
EO 4938
if thats any help
