Robbiedundy
Gti6 Brake Setup, Compensator Needed?
Robbiedundy
Hello, I'm going to be running front and rear gti6 calipers on my 205, I've run the brake lines as the 1.6 gti setup and completely forgot about the chassis mounted compensator the 1.6 uses. Will I need this with gti6 brakes?
Thanks.
In my experience, yes, and you might even find the rear brakes are still a bit too keen with it fitted.
Probably not. In the past I've had a couple of 205's with GTi-6 front brakes and they've been fine without a rear compensator when running rear disks, still locking the fronts first.
Robbiedundy
Cheers guys ????
