Rakandy
Where To Connect Those Wires?
Rakandy
Hello, I have two wires that are not connected. Anyone knows where should they be connected?
1. Wire coming from the back of the gearbox:
2. Wire comming from the bunch of wires bellow ignition coil:
Number 1 is the crank sensor, it is only used for diagnostics by Peugeot dealers using a now obsolete device, it provides the RPM signal. Normally it is just held on top of the cam cover by a tag. As it is not used you can safely remove it.
Number 2 looks like the wire for the oil temperature sender, look on the oil sump near to the drain plug and you should find a sensor with a wire missing.
Rakandy
I have other wire connected to the oil temperature sensor. Now I see that the connector No. 2 is alike the one from the brake pad sensors. However, then I have the wire missing from the right side, where should it come from?
toolie72
On right side (on my car at least) it comes along from the front of the car (near spotlight wiring) and probably ran behind plastic splash guard (that I fell out with and threw away in a rage haha)
