scottc2010 0 1 Cars Posted October 14, 2016 Hi, I have a knocking that has turned into the car wobbling slightly - I have replaced the front suspension both sides, arm on the passenger side and both drop links. I have had a feel of the bellows on the passenger side and at the joint of the track rod I can move something which feels like a bolt - is this something fairly easy to remedy? Share this post Link to post Share on other sites
Miles 331 1 Cars Posted October 14, 2016 If you have play on the rack (Pass side) it's the bush worn (Common) dead easy to replace but the rack needs to come apart, parts around £4.00 but worth doing it all 1 Share this post Link to post Share on other sites
scottc2010 0 1 Cars Posted October 14, 2016 Thanks, I will check this out in the morning Share this post Link to post Share on other sites
scottc2010 0 1 Cars Posted October 15, 2016 Hi, I have managed to free the bellows on the passenger side and slide towards the track rod end - it has revealed a bolt or washer that is loose - it is round with one flat end - is this broken or can it be reattached? Share this post Link to post Share on other sites
scottc2010 0 1 Cars Posted October 15, 2016 In addition there was a donk with the steering - I have had new suspension and the top mounts were checked and ok. I have tightened the main bolt on the top strut which has helped - there is a bolt inside it with an allen key too but not sure what if anything I should do with this also Share this post Link to post Share on other sites
welshpug 1,646 Posted October 15, 2016 hard to tell from your description without a picture. the allen key hole in the top of the damper is to hold the shaft whilst you tighten the nut. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted October 15, 2016 They should be no bolts under the bellows, it;s the arm that has a ball joint which itself screws into the rack with a washer with a locating tap and a spring locking tab washer, For the £15.00 they cost it's worth doing Share this post Link to post Share on other sites
Ozymandis 96 Posted October 16, 2016 Is your steering rack manual or power assisted? Share this post Link to post Share on other sites
scottc2010 0 1 Cars Posted October 16, 2016 Thanks for all the help - I will investigate these and buy some new parts if needed My steering rack is manual Share this post Link to post Share on other sites
scottc2010 0 1 Cars Posted October 24, 2016 it turned out that this wasn't a problem - in fact the middle section of the top strut mount had been fitted upside down ​ Share this post Link to post Share on other sites
