scottc2010
Track Rod Bellows Help Needed
scottc2010
Hi,
I have a knocking that has turned into the car wobbling slightly - I have replaced the front suspension both sides, arm on the passenger side and both drop links.
I have had a feel of the bellows on the passenger side and at the joint of the track rod I can move something which feels like a bolt - is this something fairly easy to remedy?
If you have play on the rack (Pass side) it's the bush worn (Common) dead easy to replace but the rack needs to come apart, parts around £4.00 but worth doing it all
scottc2010
Thanks, I will check this out in the morning
scottc2010
Hi, I have managed to free the bellows on the passenger side and slide towards the track rod end - it has revealed a bolt or washer that is loose - it is round with one flat end - is this broken or can it be reattached?
scottc2010
In addition there was a donk with the steering - I have had new suspension and the top mounts were checked and ok. I have tightened the main bolt on the top strut which has helped - there is a bolt inside it with an allen key too but not sure what if anything I should do with this also
hard to tell from your description without a picture.
the allen key hole in the top of the damper is to hold the shaft whilst you tighten the nut.
They should be no bolts under the bellows, it;s the arm that has a ball joint which itself screws into the rack with a washer with a locating tap and a spring locking tab washer, For the £15.00 they cost it's worth doing
Ozymandis
Is your steering rack manual or power assisted?
scottc2010
Thanks for all the help - I will investigate these and buy some new parts if needed
My steering rack is manual
scottc2010
it turned out that this wasn't a problem - in fact the middle section of the top strut mount had been fitted upside down :wacko:​
