Telf 224 2 Cars Posted September 25, 2016 I took my rear lights out today and discovered I can see through to the tyres on both sides. The body has gone rotten in the vicinity of the rear side bumper mounts. Has anybody else had this issue? Looks like a lot of work to fix. Share this post Link to post Share on other sites
murtaghp 3 Posted September 26, 2016 Pretty common I'm afraid. Mine was exactly the same. There are some repair plates available from SkyQuake in the group buy section titled "rear bumper mounting brackets" The bumper needs to come off an all the rotten panel removed then the new bit welded in. Good luck Share this post Link to post Share on other sites
Telf 224 2 Cars Posted September 26, 2016 Cheers Paul- will have a look now Share this post Link to post Share on other sites
ATK 140 1 Cars Posted September 26, 2016 Yep same here have a look at myvthread had it repaired using skyquakes parts, good as new! Share this post Link to post Share on other sites
Telf 224 2 Cars Posted September 27, 2016 Over the last couple of years I've had to send the car in twice to a bodyshop as the front of the rear arch has rusted. Does the water getting kicked up from the arch transit via the current hole in the rear and end up rusting the front? If that makes sense to anyone! Share this post Link to post Share on other sites
