Eagle1903
Any Experience With Catcams 4900365 Fast Road Camshaft?
Eagle1903
Dear Friends,
I would very much appreciate if you could share your experience and views regarding the camshaft in the topic title.
I am building the 1.9 engine with the standard ECU and planning to use this camshaft since I already have it.
Also, could you please let me know the CR you are using with this camshaft ? I am planning to have a CR around 10.2-10.4:1 although I have not checked the inlet valve closing angle of this camshaft which will would be an important factor in terms of an acceptable Dynamic CR.
Regards,
Should be good with that CR, as it's only a little bit bigger than standard.
Eagle1903
Thank you very much. I think so too. Even with 10.5:1 CR, dynamic CR is still in the good range.
