soundguy
Afm Bracket
soundguy
Simple question, what/where does it bolt to and does it need particular pitch bolts?
Edited by soundguy
bolts to the battery tray with m6x1.0 bolts and nuts
soundguy
The battery tray also holds the gearbox mount doesn't it, that bolts to the tray as well?
Then the tray bolts to the chassis arm with two thicker bolts and the battery tray can only bolt onto the chassis arm one way?
Because I've tried all ways to get the AFM bracket to mate up to the tray but can't find the right 'orientation' to pass bolts through.
soundguy
Can anyone else help with this please?
murtaghp
What year is your car and more importantly is it Motronic or Jetronic?
I have a Motronic car and had to heavily modify a Jetronic bracket to fir my AFM
soundguy
Jetronic Bosch 0280000359 Ecu. The bracket fitted OK, was removed for engine out after front end damage.
Edited by soundguy
