Paul_13 212 1 Cars Posted May 25, 2016 Does any one have the pin out for the gti dash gauges? Need to find out what pin serves the glow plug light Share this post Link to post Share on other sites
Ryan 99 Posted May 25, 2016 (edited) Pin 1 of the yellow connector according to this list I found online many years ago. Not sure if the list is 100% accurate, but it seems fine from the bits of wiring I've used it for. White Connector1 - n/c2 - Oil pressure gauge3 - n/c4 - Coolant temp lamp5 - n/c6 - Coolant temp gauge7 - Oil temp gauge8 - ABS / water in fuel filter lamp9 - Engine management lamp10 - EarthGreen Connector1 - n/c2 - 12V3 - Dashboard illumination4 - Earth5 - Choke lamp6 - Switched 12V7 - Coolant level lamp8 - n/c9 - Left indicator lampBlue Connector1 - Ignition lamp2 - n/c3 - Not sure4 - n/c5 - Right indicator lamp6 - Not sure7 - Dipped beam lampYellow Connector1 - Glow plug lamp2 - Oil pressure lamp3 - Brake warning lamp4 - Main beam lamp5 - Fuel gauge6 - Low fuel lmap7 - Not sure8 - n/cSmall Blue Connector1 - n/c2 - Tacho signal3 - earth4 - Switched 12V Edited May 25, 2016 by Ryan 1 Share this post Link to post Share on other sites
Paul_13 212 1 Cars Posted May 25, 2016 Nice one many thanks Share this post Link to post Share on other sites
jackherer 543 Posted May 26, 2016 There is a similar list here: http://www.205gtidrivers.com/articles.html/_/articles-guides/body-interior-ice/instrument-panel-explained-r46 Double check everything because I've used these lists and found discrepancies before. Share this post Link to post Share on other sites
