Neil205 1 Posted May 8, 2016 So none of the washers where working , I could here the pump on the rear one so took all the piping apart and it was blocked that now works. Front ones weren't blocked but can't hear any noise from the pump , do I need new pump ? I've tried cleaning the earth and wiring but no luck . Anything I'm missing ? Share this post Link to post Share on other sites
toolie72 67 1 Cars Posted May 8, 2016 It's beside battery so drive it direct from battery-if it works then it's a wiring issue-if it doesn't work it's dead Share this post Link to post Share on other sites
Simes 248 2 Cars Posted May 8, 2016 The switch can also be at fault. If you hear the relay clicking switch is fine and pump isn't. The contacts on the pump are often corroded and old. Share this post Link to post Share on other sites
ATK 143 1 Cars Posted May 8, 2016 I had same problem last week and it wasthe wiper stalk. Run a wire from positive on battery to one of the terminals on the pump, if pump works it's either corroded wiring or the stalk. If wipers work I think this rules our relay but not sure Share this post Link to post Share on other sites
Neil205 1 Posted May 8, 2016 Ok thanks guys I'll try both in the week Share this post Link to post Share on other sites
woodymi16 24 2 Cars Posted May 9, 2016 If the rear is working OK swap them around, should confirm if it's pump or wiring. Share this post Link to post Share on other sites
