blandy
Track Focused Set Up
blandy
Been reading though historic threads all morning and not got very far as all very mixed opinions.
My 205 is track only with gti6 engine. It's currently fitted with gaz gha coilovers and rear dampers and that is it suspension wise everything else is standard (rebuilt but standard beam)
clearly I'm not getting the best of the car with the current set up - currently set hard up front and around mid way on the rear damping which seemed best,
Could you advise what I should be looking at purely for track use
bilsteins, more rear spring and bigger arb.
3J diff, 23mm torsion bars and 25mm min ARB.
tyres
blandy
Forgot to say u do have a 3j diff installed
Enjoy the GAZ for what they now, but keep in mind you'll be looking for something better eventually. I've re-valved my front Bilsteins three times now (at $200 a pop) for each time I've increased the front spring rate. I really should have spent another $600+ on a better quality adjustable front shock.
What sort of cage do you have?
Edited by petert
woodymi16
You need to set a budget and upgrade accordingly as a high spec upgrade in one area will show up a shortfall elsewhere.
Plenty of info on here but Peters advice is spot on.
I have a full welded in roll cage, AST 5300, 23mm torsion bars, 25mm rear ARB, Yokohama A048 tyres, Kaaz diff.
blandy
I have a weld in multipoint cage that picks up on both front and rear suspension points think it's a custom cages cage.
Ascot budget bit like everything it's a bit of a long term project so not strictly got a set budget but would like to make use of the gaz set up I have so could change sprig rates etc (have no idea what's currently on it as they are as they come from gaz) so if I was to make use of those say £750-£1000
Also need to do something with the fuel set up to either a 1/2 tank of swirl pot do few things to do
allanallen
Bigger bars will improve it massively, the springs you have will be far to stiff to match the standard rear end.
blandy
Makes sense why the rear feels so loose.
Would the spring rates be printed on the springs up front? As I'm guessing that'll have a effect upon the ideal size torsion and anti roll bar on the rear
Is there a "ideal" front Spring rate to torsion bar/Arb
It's impossible to make the rear too stiff, short of making the shocks solid. Ideally, the front spring rate should match the rear.
blandy
Been looking on google where are people buying Arb and torsion bars from nowadays? I can only find spoox or pug 1 off at the min which I doubt will be the cheapest
